Belt Squeal with edge
Im woundering if any one else with the Edge Evolution programer finds that with it set on level 3 some times on a 1-2 shift it sounds like the serp belt gives a good squeel, a side from the squeel i love this thing. does any one know any thing about the nitrous controler that was on "Trucks" i cant find any info on it any were. Im new to this forum so thanks in advance for any info.
The belt loss of traction is usually the result of faster transmission action as well as improved engine torque.
The fan, water pump, alternator and other driven equipment cannot change speeds as fast as the engine load changes become, with an aged belt and pulley condition.
As you may know, the stock program is torque based and soft in action. That is what you are trying to get away from by using a tuner.
Often the only remedy is a new improved belt.
My 02 has encountered the same thing with a tuner in place until I make adjustments and change a belt that has 70k miles on it.
