What is 1/4 mile times on stock f-150
Old 09-26-2006 | 08:13 PM
donyboy1's Avatar
Hi
I would like some base information on the ford f-150 extended cab 5.4 3v stock factory.
I would appreciate the best guess estimate or facts on 1/4 times for these trucks.
I have been working on one of these and was dissapointed with the performance . I have done the basic modifications air intake headers exhaust tuner sct or diablo rear gear change to 5.46 24 tires the time slips kept coming up 7.10 to 17.20
I might be wrong and this is good clue me in so I can sleep tonight grin thanks all Don
Old 09-27-2006 | 12:02 AM
built54's Avatar
Not trying to be mean, but could you add some punctuation in there? Im confused. Do you have all those mods, or are you asking if you should get gears? and is 7.10 ur 1/8 or what? a 17.20 is about right though.
Old 09-27-2006 | 02:38 AM
NASTY-FX4's Avatar
You have way to much gear 5.46!@#$ You should be running 4.10 or 4.56 gears with 28 to 30 inch tires.The set up you have should have a hell of a 60ft,then goto crap from there.With the gears and tires you are running,you would have to start in 3 gear and run past 1/8 mile going into O/D.
Old 09-27-2006 | 06:40 AM
donyboy1's Avatar
Hi yes i have all these mods and I goofed the gear is 4.56 not 5.46. I have both kinds of tuner sct and the diablo i was not clear huh so 17.20 is in the right area ?my 60ft=2.477 1/8 = 11.066 1000 14.35 1/4 17.17 80.0 mph
this was its first run some of the guys said it would wake up after several more runs the electronics ..
thanks for the information
Old 09-27-2006 | 06:43 AM
donyboy1's Avatar
Hi yes i goofed trying to go fast i have 4.56 not 5.46gears In the reply to 54 i put the times on the first run the second was nearly the same maybe check those out and let me know it sounds maybe 17 se with the mods is about right ? now where from here NOS is going on next likely 1 second off the time ..
Old 09-27-2006 | 09:44 AM
built54's Avatar
Yeah you might loose a second with a good shot of nos... All my mods, i cant get away from high 15's... The truck is just too heavy.
Old 09-27-2006 | 09:52 AM
FX4 Matt's Avatar
Registered User
I'm with built54, our trucks are heavy! even with all my mods I can't get any better than 15.2
Old 09-27-2006 | 11:23 AM
NASTY-FX4's Avatar
Does know one run a high stall torque converter?FX4-Matt your truck is running good for its size.
Old 09-27-2006 | 12:39 PM
Trooks2001's Avatar
Seems like you should be doin better than 17's. Hell I'm gettin high 16's with my tank.
Old 09-27-2006 | 02:20 PM
Scandall's Avatar
Hey man it says your truck is an 06, from what I have read on these forums these trucks don't really wake up until you get some milage on them. How many miles do you have on your truck. ?
Old 09-27-2006 | 03:10 PM
Adam06FX4's Avatar
Registered User
damn im getting high 15s and the only mod i have is the edge. factory exaust, factory intake plus the added weight of 20s
Old 09-27-2006 | 03:42 PM
KickinBlue4x4's Avatar
Your supercharged arent you???
Old 09-27-2006 | 04:30 PM
openclasspro#11's Avatar
#'s
-matt are those #'s with the headers?-phil
Old 09-27-2006 | 06:01 PM
built54's Avatar
No, it was about 98* outside, very high humidity when i got high 15's
Old 09-27-2006 | 09:00 PM
FX4 Matt's Avatar
Registered User
Nope I have not been since the headers I'm going to try and go this friday
Quick Reply: What is 1/4 mile times on stock f-150
