Edge Installed but have a ?
? for Edge owners. I just installed my Edge Evo on a 2006 FX4 5.4 with only around 4000K miles on the truck, Love the difference can't even get my self to return to stock with my concern.
Went out with Level 2 on when wife decided to go up see her sister about 5 to 10 miles uphill ride and when we got to the top we smelled like burnt clutch or brake coming from the engine, Is this normal ? Is this part of the engine performance adjustment or something. Should i be concerned about this and return to stock programming. I also adjusted the tire size ( i have 35" Tires ) on the edge other than this i haven't done it mods to the level 2 program.
Feedback will be highly appreciated.
No, not normal at all. I have a hard time believeing that the tune had anything to do with it. Sounds like friction of some kind and just coincidence. Every now and then, I get a little belt slippage when I get the hard shift at WOT, just a slight screech. You may have an emergency brake sticking or something like that.
It only happened after the 5-10 miles of steep climb but on our way down we did not smell anything at all.
Originally Posted by coloFX4
I would re-load your stock config and see if the problem continues. It might be something else, but good to see.
