Unplugging the Edge
Like Chester said...it doesn't really matter.
If the vehicle is turned off, it will ask you to turn the key to the ON position. It will then go through its bootup process. At this time, it should recognize if you are running level 1-3. If it incorrectly identifies which one you had, CALL EDGE. Or if it tries to tell you to custom program it, CALL EDGE.
