Having a problem with new Edge
Well I guess I'm one of the unlucky ones. Installed my new Edge Evo today. Read the directions and followed step by step. Everything went fine. Set level 2. No problems yet. Went for a test drive. Started right up, got out of the driveway and started up the steet.
Now there is a problem. Acceleration cut out right away, engine still running but no throttle response. All I am getting is sporadic acceleration. Then nothing. Set it to level 1 per instructions. Same thing. Set it back to stock. Same thing. Unplugged the unit. Waited about 20 min. Plugged back in and its showing that I am on level 1 still. Even though the set default process said it worked.
Also, the speedo is going all the way up to 120 but I am coasting down the street.
Called Edge, got disconnected three times while on hold. Then got the after hours message.
Damn!
Any Ideas. (obviously I need to call them on Mon.)
PB
Damn!
PB
I think it's stuck on level 1 now. It says its restoring defaults(returing to stock) but its not. I tried to download updates but I think since its not on stock settings it won't let me. Debating whether to take it to the dealership today, if their open, or wait till mon and talk to edge. and miss work.
I'm sure I followed the directions. It said it was successful after the programming.
Ok so I put the thing back in my truck after my last post. Now on the power levels it says return to stock. I don't think I had that option last night. Maybe I was too PO and didn't notice. So anyway it went back to stock and the truck is running correctly now. Thank God! I think I will try to update but not re-program untill Mon. when Edge is open.
I guess the restore defaults is just for options within the edge and has nothing to do with the trucks settings.:o
THanks for the concern its nice to share these kind of issues with you guys.
