Results!!
Results!!
I know that many of you on the forum are running custom tunes from troyer. What kind of result are yall getting. I have a k&n intake and sido flowmaster and was wondering what kind of numbers will i be looking at if i decide to go to troyerThanks and sorry if this question has been asked 100 times.
Originally Posted by MGDfan
And... it's not just about peak numbers - it's about "area under the curve", and vast driveability improvements - things you simply will not get to anywhere the same degree from a canned tuner.
The Edge "canned tune" has a night and day difference for "driveability improvements" for my truck. If it is not just about peak numbers MGDFan then why do you keep bashing the "canned tune"? If you do not dyno your "custom tune" would you not agree it is a canned tune?
And nope - a Custom baseline tune that is dead nuts perfect (requires no adjustments after data review), is simply a perfect custom tune, done in the first iteration. Which is the result of raw talent & experience.
The difference is in the details. Repeat - not bashing.
Beers, remember?
CamoMan
An Edge tune is canned but still not a bad tune. It is for every truck with the same strategy regardless of any mods done by the owner. It is not optimized for your truck and driving choices like a true custom tune.
Originally Posted by Norm
No, a Troyer Performance tune even without dyno and datalogging is still a custom tune created for your truck and mods based on the info you provide to TP. Dyno and datalogging is just to verify that Mike's tuning was on the money and to see if any more can be gained by tweaking here and there as every truck is a little different.
I have seen TP post on here that one truck can be so much different then another equiped with the same mods or stock. So how can you not dyno to have a true custom tune? It is a canned tune until it is put on a dyno.
As we said the dyno is just to check his work and tweak if needed.
It is custom because it is made for one truck not all trucks with the same code. It is custom because you fill out a worksheet and tell him what you have and what you want and how you drive and he tunes based on that. How much more custom can you get?
Why would you need to tweek the tune? To make it custom to your truck. Until you tweek it is a canned tune IMHO.
We have explained it several times now and you still do not get it. What can we help you understand?
It is custom before tweaking.
