Help finding diagnostic tool
I don't know if this is the correct area for this post, but here goes. I'm wanting some small type of monitoring device to keep an eye on engine/tranny, etc.. I've looked at the ad for the dash hawk, and this is kind of what I'm looking for. I'm not looking to change the tuning of my truck, just monitoring basically. Do they make such a thing that is relatively inexpensive and almost a "plug and Play" type of install?
Just thought it would be nice to keep an eye on things as I'm driving.
Thanks in advance for any input.
Originally Posted by ParkM
You could just run whatever gauges you were looking for, and monitor whatever you need. I would trust autometer gauges before I would ever trust a scangauge, that being said what are you looking to monitor?
I've seen a mounting kit for the scangauge that cleanly mounts it directly above the rearview mirror, where the dashhawk would need to be mounted (for easy viewing) on the dash as the name implies.
I guess at this point, I'm leaning toward the Dashhawk for what it does. Just wish it was a little cheaper. But I guess you gotta pay for the extras, right?
I have the older Scan Gauge and it has worked good for me.I didn't think about reading the tranny temp when I got it.I've used it on other vels to read codes and reset the check eng light.I payed about $125 for it and now they are $169 and do more.The temp reading I saw a change running a K&N and stock filter,the K&N ran cooler. The other readings tell you alot too,for your gauges don't tell you that much in numbers like the Scan Gauge does.The $300 is high but if it does what you want it to do get it.
trust a scangauge?
