Lets see your Edge custom tunes
Originally Posted by SR89racer
i tried to use a custom tune but every time i do my truck wont shift and acts all crazy like it is stuck in gear unless i drive real slow. any ideas?
Originally Posted by BSL
Ok here's what I finally settled on, after limited testing (just driving around town) I've gone with level 2 (never actually tried level 3 yet, I'm never on the open road and can't really justify the extra $.30/gal for a few min of fun)
WOT shift 1-2=5300, 2-3=5300, 3-4=4800
Firmness 1-2=+8, 2-3=+8, 3-4=+5
Rev Lim 5450
Speed 110
Gears 3.55
Tires 2445 (measured, way off what the manual said for 265/70R17)
Timing +1.5 (I'm at 6000 ft running 87 oct, so you may not want to use this)
WOT 1.6
This appears to be a pretty driveable tune, although I may bump down the WOT shift for the 1-3 points, it seems to scream a little too much .
Rev Lim 5450
Speed 110
Gears 3.55
WOT 1.6
WOT shift 1-2=5250, 2-3=5250, 3-4=4850
Firmness 1-3=+4, 3-4=+3
Rev Lim 5400
timing +1.5 (again at 6,000 ft running 87. adjust yours accordingly)
WOT 1.5 (the air is thin here)
Even though this thread kind of died I'm posting it as a reference for others in the 97-03 group to have a reference
So after a little more reading and a little more driving I've settled on this one for level 2
Rev Lim 5400
Rev Lim 5400
Originally Posted by mgp32
Im at around 1,000 feet above see level(Central Minnesota). What do you think I should put my timing and WOT at?(my mods are listed below)
what part of MN? I'm origionally from central ND and have alot of family in the Dawson and Forest lake areas. I would say you'd be alright without customizing 87 on level 2 and 91 on 3, the way I got my timing figured out was to just bump it .5 and then drive it for a few days and see how it was, the engine kept feeling better and better until I hit +2.5 then it didn't feel right and felt like it was loosing power from the previous tune, so I went down to +1.5 just to be safe and not get any detonation (which I never heard). If you hear detonation back it off, cuz that will cause you problems, as far as WOT fuel alot of people in various locations run 1.6, again mine just felt better at 1.5, personally I would adjust the two of them seperately to make sure you get it right for both. good luck
So you think I shouldnt customise?
I just recently got my Edge so I have been fairly conservative on the custom tuning. So far these are the settings I have on my 2003 F150 5.4L FX4:
Level 2 Tow running 89 octane
Timing +1
WOT Shift 1-2=5200 2-3=5200 3-4=4800
Shift Firmness 1-2=+4 2-3=+4 3-4=+2
Rev Limit 5400
WOT Fuel 1.5
Top Speed 110
Gear 3.55
Tire Size 2526mm (measured for 285/70/17s)
Timing +1
Rev Limit 5400
WOT Fuel 1.5
Top Speed 110
Gear 3.55
Timing +1
Rev Limit 5400
WOT Fuel 1.5
Top Speed 110
Gear 3.55
Timing +1
Rev Limit 5400
WOT Fuel 1.5
Top Speed 110
Gear 3.55
I like a firm, hard shift.
