Lets see your Edge custom tunes
Old 02-01-2008, 11:30 PM
LariatSCrew04's Avatar
Originally Posted by 2005lariatky
I do both. My edge isnt accurate.
Didn't think mine was very accurate either. It said 17mpg for the 30 miles on the way to work and only 15mpg on the way home, I drove the same speed both ways. I'll figure out what it is over the next couple weeks tho once I go through a couple tanks of fuel.
  #122
Old 02-05-2008, 01:37 PM
F150paratrooper's Avatar
MPGs
ok, just got back from a trip over the weekend. On LVL 2. Truck computer said 17 MPG, edge said 18.5. I drove right at 1000 miles doing the speed limit +/- 2 mph. I did have to let the truck run for 30 minutes one morning to clear the ice off the windshield. I don't own an ice scraper! ( I love NC). Anyway I'm headed out again this weekend about the same distance just a different location. this time I will figure the MPG manually too and see what happens.
oh, I did put my foot in it as couple times because of idiots! But I love the power the edge gives me.
  #123
Old 02-05-2008, 05:31 PM
Kabby's Avatar
Is a WOT of 3.0 to high? I see that everyone has 1. somthing. Thanks for the reply!
  #124
Old 02-05-2008, 05:35 PM
Super Moderator
What are you talking about as +3.0?
Old 02-05-2008, 05:44 PM
Kabby's Avatar
Yes 3.0
  #126
Old 02-05-2008, 05:49 PM
Super Moderator
Yes 3.0
Timing, shift pressure, fuel? what are you setting?
Old 02-05-2008, 05:51 PM
Kabby's Avatar
Haha sorry for the lack of info, I am talking about the WOT fuel setting to + 3.0. Thanks blue!
  #128
Old 02-05-2008, 05:55 PM
Super Moderator
Edge advised in the beginning that 1.5 or 1.6 was the best for WOT fuel.
Old 02-05-2008, 05:58 PM
Kabby's Avatar
Ok, thanks blue.
  #130
Old 02-19-2008, 09:52 AM
shiftonthefly's Avatar
Smile 2002 fx4 5.4
bsl i noticed you have 02 fx4. i also own 02 fx4 5.4. i was wondering if your truck still reacts positivly to the tune you have on it. I dont have a tune on my truck.i am a little leary of doing this. myfx4 runs fine its all stock.i was ju st wondering what made you install a custom tune and are you satified. thank you for taking the time to share your thoughts with me.
  #131
Old 02-19-2008, 06:20 PM
garrett720's Avatar
I was wondering if I have my edge programmed right for what exhuast I have and what gas I run. I have a 2004 F150 5.4 supercrew with a siso 14" magnaflow exhaust and the new EDGE (15051) set at the stock level 2 settings with only the speed limiter changed and I run 93 oct gas. I have tried some of the settings I have read on the web and cant seem to find one I like. So far I think my best milage is with the level 2 stock tune. Is my set up okay or is there something better I can do to tweak it out a little more. Any ideas are welcome. Thanks
  #132
Old 02-19-2008, 06:37 PM
Ftruck05's Avatar
If you are running 93 you could bump the timing on lvl 2 +1.5. Or you could run lvl 3 with the timing bumped +1.
  #133
Old 02-19-2008, 09:45 PM
garrett720's Avatar
Im gonna give those two a shot. Yesterday I tuned level two to timing +2 and at idle if I just gave it a little bit of gas slowly it kinda felt like it wanted to die out, so then I changed it back to 0 because I didnt want to hurt anything but the take off was nice at +2. Im really looking for the most mpg tune. Thanks for the help I have been reading on this site for a while and finally decided to join in.
  #134
Old 02-26-2008, 03:13 AM
wifordx4's Avatar
ok i finally got myself one and i love it gotta play with the wot shifts a bit yet as it is touchin the rev limiter but i can figure that out my only prob is it sounds like it has more fuel than it knows what to do with @ 1500-1900 rpm still has good power if u romp on it but just sounds wierd any one else notice this i have no muffler just a y pipe and 2 tail pipes after the cats i got an airraid intake that will go on as soon as the damn snow stops thanks for any help you all can provide
  #135
Old 02-26-2008, 08:32 AM
2005lariatky's Avatar
First please use punctuation. This isnt a text message. Next your WOT shift should be no less than 300rpm more than you highest shift. I have no clue for the sound. Could be your exhaust droning. Also the Edge is designed for a stock truck. The airraid may cause a Lean condition as the Edge is not tuned for that. There is a guy on here, Bill (ASEMechanic) that can custom tune the edge for a fee. Post your tune and we can see what you have going on and offer some advise. www.powerhungryperformance.com
Quick Reply: Lets see your Edge custom tunes
