Edge Gas Mileage Sucks! Bill????
Ok I have had the edge for a few months now and I have been averaging less than 14.5mpg the hole time. Not so great. The last fill up I calculated it to be 13.3mpg. This is horrible and the edge calculation is way way off. It said 15.2mpg for the average and when I calculated I get the 13.3mpg. I am running level 2 87 octane, shift points set at I think 5200 1-2, 5200 2-3, and 4900 3-4. Spark +.5 and Trans Pressure +4 1-2, +4 2-3 and +2 3-4. Any ideas? I thought I would get better? Truck has 14,000 miles. We are running winter grade fuel with "up to" 10% Ethanol. At this time last year with no edge and the same driving style and area I was getting 15-15.5mpg. I was hoping into the 16's. This is a combination of city and interstate driving.
Overall, fuel quality is going down,and this year there are far more fuels with ethanol content than there were just last year - and that is the primary reason why people comparing last year's mileage at this time to this year are seeing worse mileage.
Now that is not to answer for what is in the tune, but I would suggest that you remove the tuning and drive it for a month or so on the stock tuning and see what mileage you get using the exact same fuels - *then* you'll have some current relevant data with which to make your comparison, so it's relevant to this year's fuels.
Good luck!
Good luck!
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
Originally Posted by F150FXOnline
Dont feel bad I get 12.5 to 15 on the hwy. average about 13.5
If I didnt have another car I drive to work and use my truck on weekends id go broke!!
bad mpg
I got my edge evo for xmas. the first week I was getting about 14 or 15mpg. I had a problem with my battery this weekend so I reflashed it and now I'm only getting around 12mpg. I don't drive like a complete anus, I get on it once in awhile but nothing obscene...what gives?! MPG is suppose to improve?!
Doug
Doug
Originally Posted by gothdesigner
what I meant was that I was worried that my battery problem may have messed up the program so I just did it over again, using all the same specs that I originally did and now my mpg has gone down by 2-3 mpg.
I'm only on level two. My only custom settings were for shift firmness and WOT fuel. I wouldn't think that those settings would drop my mpg that much unless I was flooring at from every stop light and stop sign and doing 90 on the highway.
It's just rather odd that it was running fine at 14-15mpg and now only at 12-13.
