Another MAF question
I need to make sure i understand this correctly: If i have a stock MAF and 19lb injectors, and I replace the MAF with a Lightning MAF and 42lb injectors, will i still be able to run on the tune that is in the ecm now until i can get to a shop? I have a lm-1 and aux box so i can log everything immediately. I am presuming that since the airflow rates are calibrated differently between the MAFs for the injector size, that the airflow tables will work. Please correct me if i am wrong here. Since i plan on the turbo being in soon, i need to finish up the details. I have the injectors but i am needing a matching MAF if anyone has a 90mm from a lightning.
Will
Will
