whats your 0-60 with edge?
#32
Ran customized at the strip, and then canned, the canned ran faster???? My shift points and firmness were upped, +1 timing and 5600 rev limit. Couldn't believe the canned ran faster???? Wasn't a huge diff. 0.10 but it did that consistent. I think the 93 is just a joke, but I hope my tune for the strip will run better when I get it.
#33
#34
Well I don't push my factory 146000 mile 4.6's timing. The modular motors are a silent felon when it comes to detonation. They can do it for along time before anyone even notices, I have seen quite a few, esp 03-04 Cobras that got a dose of boost and no timing changes, that come in with really "beaten up" pistons and busted ring lands. I run .5 for my altitude and .5 because I feel ok with it.
#36
Originally Posted by jasonkola
you are running that on an 87 tune right. I wasn't suggesting running +3 with 87 octane but + 3 with 93 octane. plus adjusting for elavation on top of that.
#37
Originally Posted by joshmac4.6
No I'm on a 93 tune, but the Edge adjusts the timing from level 2-3 that and the shift points and firmness make the 93 tune, it is not the same as the 87. So I would watch the timing increases, the Edge adds them already so you could be running 5-6 degrees over the 87 tune. Just food for thought.
#38
Originally Posted by Ftruck05
The Edge compensates timing for 91 octane, not 93. So on lvl 3 with 93 you would only want to bump the timing +1. If you were to run 93 on lvl 2 you could bump the timing +3
#39
ok yea the tires are about 2" smaller than the factory 275's on 18's. Didn't see that, but it still seems a little fast for the truck but maybe its accurate. Take it to the strip and post the nums, I run high 10's in the 1/8 so yours *should* run high mid 9's or so. The 05 5.4 I raced ran 11.0's on factory 17's.
#40
Originally Posted by openclasspro#11
i ran a 16.2 in the low 10's and you run with a 16.05 civic but your 0-60 is high 10's? yes i had 3.55's-you mean to tell me you're all top end?
#41
#42
Hay joshmac4.6 I have been thinking about all the racing you are doing with that 4.6 with 146,000 miles on it. you migh twant to stop racing that thing before you kill it. You are really pushing an old engine hard. you will be lucky to make it to 160,000 pushing it so hard.
#43
Originally Posted by BLACKO4FX4
i promise you it is stock!!! other than adjusting the level 2 canned tune....also i have the wheel adjusted to the right setting, if i romp on it from a stand still it will squeal the tires pretty good. and according to the edge 1/4 mile setting ive been running 15.6 to 15.7 consistently.....i have no reason to lie and i dont even have custom exhaust, i do have 373 gears and a 5.4
It's inaccurate, trust me. All you have is the Edge set on level 2 and you're in the 15's?
Check out my video and then come back and tell me you believe you're REALLY running 15's.
http://youtube.com/watch?v=MsaqjMyRfLM
My Edge also said I was running 0-60 in the high 6's but that doesn't add up to my 1/4 time when I went to the strip.
