whats your 0-60 with edge?
well I have been out playing with my edge today doing alot of 0-60 runs to see what my truck likes. mainly I was playing with the timing. my best 0-60 run was 9.59. that was with + .5 and my second best was 9.62 with +1 timing. I am running 87 oct. so I desided to go back to +.5 just to play it safe. so what is everyone getting for 0-60 times with the edge. I may go out an play with it some more tomorrow. and mess with the shift points and wot fuel some more. sense I was mostely messing with the timing and running the shift firmness up at 25. I think tomorrow I will bring the shift points up some and the wot fuel. but I may bring the shift firmness down a little. every time it shifted at wot I heard a squeal. at first I thought I was hearing the tires chirping but it sounded to high pitch more like a belt slipping. what do you think that was? maybe just the engine belts slipping. maybe the tranny. I am not sure so I am going to bring it down to +20 shift firmness.
30 bucks at Autozone. While you're there, rent the serpentine removal kit for 20, go outside, change it (first time took me 30 mins, now less than 5), return the kit and get your money back ![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
Make sure you take a picture/make note of how the belt setup is. Basically, if the pulley is "smooth," the back of the belt goes on it. If grooved, but the grooves there.
![thumbsup](https://www.f150online.com/forums/images/smilies/thumbsup.gif)
Originally Posted by joshmac4.6
7.55 in my 98 4.6.
And thanks for the tips on the belt elvato that will come in real handy sense there is a autozone like 6 blocks from my house.
No mine has 146,XXX of straight hell, no big power adders, or my custom 93 tune yet, but I was on lvl 3 "customized". It ran a 7.88 in 2wd spinning a little and 7.55 in 4wd. My truck hits the scales at 5800+ lbs, so not too big of a weight diff., but I was running stock 245's at the time, so with my 265's it is a little slower.
I think 7.62 is a pretty good time compared to what I have been getting. you got a supercrew I have fx4 supercab. I am not sure the weight differance but my truck weighs 6100 on the scales. I was out tweeking my custom adjustments today and got my 0-60 down to 8.6. which I was pretty happy with. I can not believe I am still being beat by a supercrew and 4.6. what custom settings are you running? I am still running 87 oct.
I was messing around on some backroads today, these runs were on lvl2. I only tweaked a couple of options in the custom menu. I left the shift points, rev limit, and timing alone. Here's my numbers
0-60 7.2
1/4 mile 15.5 @89mph
FIRMNESS
1-2+10
2-3+8
3-4+8
SPEED 130
GEARS 3.73
WOT FUEL 1.5
TIRES 2632
0-60 7.2
FIRMNESS
1-2+10
2-3+8
3-4+8
SPEED 130
GEARS 3.73
WOT FUEL 1.5
TIRES 2632
Originally Posted by wallst
the best time ive ran was a 7.2 on level one 87 octane. its weird but ive tried on level three and not gotten any better, i dunno if i was doin somethin wrong but i was thinkin it shoulda gotten better
