Dreaded drone?
Old 06-11-2008 | 03:57 PM
muliefever's Avatar
Dreaded drone?
I got the S&B matched up with My Gryphon and a fowmaster single 3" exhaust. And I love it!!!!!! However, I get the drone around 55 mph. Will that disappear with my custom tunes? Man I hope so.
Old 06-11-2008 | 04:21 PM
ThumperMX113's Avatar
More than likely. I was running the S&B CAI with the Edge and I got the horrible drone about 1700 RPMs. I ended up switching to a custom tuned Xcal2 and it went away. My guess is that it's going to be gone once Bill sends you his tunes.
Old 06-12-2008 | 12:16 AM
JackandJanet's Avatar
Everything I've seen in this forum tells me Thumper's right. The custom tunes will fix the "drone".
- Jack
Old 06-12-2008 | 12:21 AM
55post's Avatar
I had the drone with that same set up. It went away with bills custom tunes.
Old 06-12-2008 | 08:07 AM
muliefever's Avatar
Outstanding!
Old 02-06-2009 | 03:12 PM
crooked's Avatar
I have the exact same drone at 1650 rpms to 1700 with my new recent installed S&B CAI. I am not really sure if the drone was there before I installed the Gryphon. I do know the intake was load but never took the truck to cruising speeds. The drone really kicks in while cruising on overpasses. I hope Bill's custom tunes can cut the drone noise in half at least. Can someone explain what actually makes this noise? If this wasn't an engine compartment, I would be dynomating this bee box.
Old 02-06-2009 | 04:51 PM
i.ride.suzuki's Avatar
Dynomat has hoodliners.
Drone is just the way the engine is handling air. A low frequency is more TQ and less HP. Why do you think F1 cars sound the way they do? They are small displacement high-revving engines that push out 900hp and only 300tq. And also your IMRCs are closed while cruising so that intensifies the drone until they open.
Old 02-06-2009 | 06:15 PM
fitz888's Avatar
I had the tunes and s+b on at the same time so i never go drone
Old 02-09-2009 | 09:36 PM
MWelsch's Avatar
I had the nasty drone also... AFE Stage 2, Magnaflow 18" SISO and Gryphon before i got the customs. With those amazing customs installed, IT ALL WENT AWAY!!!!
Old 02-10-2009 | 09:01 PM
fitz888's Avatar
I wonder what causes the pre tune drone on the intakes maybe one of the tuners will chime in and explain this to us.
Quick Reply: Dreaded drone?
