Gears or Tuner?
Gears or Tuner?
Hello all, I have 01 4x2 super crew with a 5.4 and 3:55 gears.
I have put a K&N filter and a RCD 6" lift with 305-70-16 tires on it.
I have recently purchased a toy hauler and am pulling around 7500lbs.
I have been thinking about adding a tuner, gears and free flow muffler. What should i go for first the 4:10 gears or the tuner?
I really need alittle more to be able to pull some hills here and there, the highway speeds have been great.
go for the tuner first, they help out a lot with the tow(i have a superchip on my 02 f150 screw 4x4 and i can tell a big difference hauling the tractor) and then you can always add the gears later and then you'll already have the tuner to fix your speed-o(which i bet is already off with those tires). but if your gonna be towing 7500 a lot better look into a 3/4 ton
![devil](https://www.f150online.com/forums/images/smilies/devil.gif)
I would go gears first. Gears will bring the final drive ratio closer to stock, since you have already increased the tire diameter. Don't get a tuner just to correct the speedometer. That would be a gigantic waste of money.
Gears will make a noticeable difference in performance. A tuner will make a measurable difference in performance. How much measuring equipment do you have?
