Superchips Question Again...
Is there anybody here with info on custom tunes for the 1714 Max Micro Tuner?
Shift points and pressure plate settings?
I have played around for some time and I dont want to press my luck now that my truck is almost out of warranty at almost 100,000.
Also does the 87 octane setting actually change the air/fuel ratio to a more rich number?
If not what is changed?
you run 87 octane to save gas? ![lol](https://www.f150online.com/forums/images/smilies/lol.gif)
a tuner like the superchips adjusts timing and maybe the a/f ratio slightly.
I'd run 91 or 93 octane with the apropriate and drive it easy if I wanted better gas mileage.
as far as perfomarnce goes set the shift points: 1-2@5300rpms, 2-3@5200rpms leave 3-4 alone.
the firmness is on you and your personal preference and IF your tranny clunks or not
