Edge Evolution II Experiences and Recommedations
Old age and treachery wins out over youth and beauty everytime, eh Bluejay? Actually the menu option Jim was referring to is called "Load Previous Settings", I think. Simply do that before you start making any changes, then, when you select "Done", your new settings become your "Previous Settings".
- Jack
- Jack
But, I'm not sure the gear ratio is in the VIN. There is a tag though, on the differential that is supposed to give that information to you. I've seen the tag on my truck but I've never crawled up under there to read it.
- Jack
Here you go. That must have been Janet, not Jack.
Yeah check the driver's door Jamb and get the code off the sticker.
19 — 3.55 non-limited slip — F-150
25 — 4.10 non-limited slip — F-150
26 — 3.73 non-limited slip — F-150/Mark LT
27 — 3.31 non-limited slip — F-150
B5 — 4.10 limited slip — F-150
B6 — 3.73 limited slip — F-150/Mark LT
H9 — 3.55 limited slip — F-150
18 = 3.08 non-limited slip — F-150
Well duh! Right there under the word "Axle"! I gotta tell you, it's hard to beat a jaybird at this game. At least though, it wasn't in the VIN, so Janet was half right.
So, I crawled under my truck and looked at the tags on my differential. One tells me to use a synthetic fluid (so it's not much help). The other has several numbers in groups of one or two digits. The one group that looked promising was: "L73" on the second row (above it was a "3" by itself) - so, if this refers to 3.73LS (which is what I have), the "tag approach" is a bit cryptic too.
I always find myself wondering why manufacturers find it necessary to use "codes" for useful information.
(And now someone is going to probably tell me what all the numbers on the differential tag mean, just to humble me even more. I keep trying to build up my "attaboys", and all I really seem to accumulate is "aw sh*ts".)
- Jack
- Jack
Last edited by JackandJanet; 08-18-2008 at 07:50 PM. Reason: Added thoughts about the other numbers in the tag
- Jack
- Jack
