f150 spark knocking
f150 spark knocking
i have a 04 f150 screw 4.6 with a edge evolution i was running it on level 2 and then switched to high test fuel and put it on level 3 now i notice when i lug it on hills it will spark knock. i put a k&n filter in the stock box and it seems like it started happening since i did that. i have been running my truck lately on the stock program so that it don't spark knock. any thing i can try?
The canned tunes in Edge's don't seem to play well with intake modifications. Call Bill Cohron at www.powerhungryperformance.com and he will tell you what you need to do to make your intake work with a programmer.
- Jack
- Jack
the only thing i messed with is i upped the speed limiter, i put 265's on my truck adjusted for them and that's it. i tried one night moving the timing in small incremets and the truck worked like crap it just fell on it's face had no power so i just left it to what the edge said i guess i'm gonna clean up my stock filter and put it back in and try that?
I wonder if he "drained" the tank before putting high test in and switching to the Level 3 tune? He could be running, say 89-90 octane.
- Jack
It's unusual, but it is sad to say that every once in a while we'll get a vehicle with slight detonation when running the 93 program. However, you can run the 93 program with 1-2 degrees taken out of the timing and that should take care of it. Go to the custom options, select the timing option and then set between -1 and -2.
Also keep in mind that fuel can make a difference. What brand ya running?
Take care.
Take care.
i took it back to -1 and the truck would barely pull away it worked like crap i put up on the screen so u could see the spark advance and it showed 1638 at idle but it was dead and didn't sound right. so i put it back on level 2 and don't spark knock is there anyway that i can make it so that u don't have to shove on the gas so hard to get it to downshift from 4th to 3rd.
About all I can suggest now is working with Bill at PHP. I'm sure he can cure all your problems with a Gryphon upgrade (very reasonable) and custom tunes.
For instance, I have a "Downshift" adjustment that I can apply for each gear setting that changes the speeds they occur at when you are using part throttle.
- Jack
