Edge Shift Firmness
I have a question on this shift firmness. I have an evo set on level 2 I did not change any of the custom setings and every time the trans shifts it shifts hard at mid / full throttle... It feals like it shouldnt shift that hard. Maybe its just me I dont know. I have a 08 f150 xlt 5.4 thanks much, Tom:santa:
- Jack
check your Gear ratio setting
Good Luck
Great post, billmtx!
This has never come up in the things I've read. I'm always talking about the default tire circumference, but I've never even considered the effect of an incorrect gear ratio. (Probably, because mine's the default ratio).
Good on you! (Shows how much you can learn from the "thoughtful" posts in these forums).
- Jack
- Jack
