Can Someone Read My Datalog???
Old 12-17-2008, 04:53 PM
Memo21687's Avatar
Can someone help me out and read my datalog from LiveLink and tell me if my truck is running good?
Old 12-17-2008, 05:28 PM
built54's Avatar
sure. email it to me
Old 12-17-2008, 05:33 PM
Memo21687's Avatar
Whats ur email?
Old 12-17-2008, 06:31 PM
i.ride.suzuki's Avatar
What DRM/PID did you datalog?
Send it to:
i.ride.suzuki at gmail dot com
Old 12-17-2008, 06:35 PM
Memo21687's Avatar
I dunno a buncha stuff that this guy at the dyno shop told me to datalog.
I just sent the email over to you i.ride.suzuki
Old 12-17-2008, 07:19 PM
It takes 6 seconds for you to ramp from closed to open loop: I can't confirm 100% with out WB readings, but that's what it looks like.
Old 12-17-2008, 07:22 PM
Memo21687's Avatar
What does that mean?
Old 12-17-2008, 07:32 PM
When you press the pedal to the floor to go wide open throttle, the time it takes for the fuel to change from 14.64:1 to 12.58:1.
Old 12-17-2008, 07:35 PM
Memo21687's Avatar
So is that bad or good?
Old 12-17-2008, 07:45 PM
Should be faster. For example, when you let off the pedal from (open loop) WOT, its commanded ramp to closed loop is in less than a second.
Old 12-17-2008, 07:48 PM
openclasspro#11's Avatar
mine is as fast going from open to closed as it is vice a versa,is that on a stock tune?whats your code on pcm?
Old 12-17-2008, 08:06 PM
Kokopellif150's Avatar
I put my closed to open at zero seconds.
Old 12-17-2008, 08:37 PM
Memo21687's Avatar
Im running a troyer tune...my PCM code is ODAL1
Does it make a diff that im running 40s and have 5.13 gears?
Old 12-18-2008, 04:08 PM
Oh god, seriously, im done with this thread. When/if you talk to troyer don't say i mentioned a thing, he will just tell you 101 ways that i am wrong.
Good luck!
Old 12-18-2008, 05:07 PM
Memo21687's Avatar
Huh?
Quick Reply: Can Someone Read My Datalog???
