Another edge question
Old 12-22-2008 | 11:05 PM
JackandJanet's Avatar
And, since the manual seems to indicate you have the "custom options", I totally agree with Bluejay. Something seems to be wrong with your unit.
It's possible there is a firmware or version upgrade that will fix it. Call Edge.
- Jack
Old 12-27-2008 | 08:57 AM
garnsey's Avatar
evolution
i just installed the edge evolution on my 05 f150, 5.4L. iwas trying to find the best way to tweak it at each level in the custom programming. what is "converting to gryphon" everyone is talking about?
Old 12-28-2008 | 11:16 AM
To satisfy emissions laws, Edge cannot allow their units to be "custom" tuned, so the canned tunes that come on the Edge are sort of "generic" and probably don't give you everything the engine is capable of. Bill Cohron at www.PHPTune.com rebrands the units as "Gryphons" and can write custom tunes for them. He used to work for Edge and was responsible for much of the original design, so you're working with someone who knows trucks and the programmer hardware. Take a look at his website and all your questions should be answered. If you decide you might like to upgrade, give him a call - you won't regret it!
- Jack
Old 12-30-2008 | 02:57 PM
slammedsplash's Avatar
Okay, here is my response from Edge about not being able to access the custom options.
Robert,
We can try to walk you through the update process when we reopen on Friday the 2nd. If you can call at that time or the following week we can try to walk you through the update process. The only problem is that we may not be able to do tire size programming on your truck. If the Evolution doesn't give you that option after the update, it may be because the vehicle's PCM doesn't give us the option to adjust that parameter. Please let me know if you have any additional questions. Thank you.
I have posted a question to Bill Cohron on his forums to see if this is true and to also find out if the Gryphon will let me access the custom options. I might be converting sooner than later.
Old 12-30-2008 | 05:05 PM
DaMoose81's Avatar
It doesnt have anything to do with the fact that he has a 97 does it?
Old 12-30-2008 | 05:59 PM
It may. He's posted on the PHP forum and I've mentioned that to him. Bill has not answered yet. It DOES seem like the folks at Edge would know this though, doesn't it?
- Jack
Old 01-02-2009 | 10:18 PM
uslangleys1's Avatar
Question Check Sum Failed
Can someone help me out?
I just downloaded the Edge "Fusion" software tonight. Apparently Edge no longer uses the Lightning software.
Anyway, I update the software in which updated my programmer and when I was trying to reprogram my truck for stage 1 it went through the process and then I received an CHECK SUM ERROR: RXAQ5B4...does anyone know how to fix this problem? Edge CS isn't open.
Uslangleys1
Old 01-02-2009 | 10:41 PM
Uslangleys1
I'm thinking you DID return your truck to a Level 0 tune before you took the Edge out to do the update, right?
If so, it's possible it's a momentary glitch caused by low voltage or something else.
Make sure your battery is fully charged, turn off ALL accessories (auto headlights, heater blower, radio, interior lights, etc.), and try again. I don't think you can hurt anything by doing ths, and that's what I'd do.
- Jack
Old 01-08-2009 | 08:22 AM
jhartley's Avatar
Originally Posted by slammedsplash
When I choose level 3 and hit enter, it tells me to turn the truck off and back on. Then it begins to program the truck.
Mine did this out of the blue all i did was update it and it went away
Old 01-08-2009 | 08:39 AM
KEITHHATTER's Avatar
I was told by Troyer that they couldn't calibrate tire size through the PCM until 99. I had the same question with my 98 and my decisions here soon.
Old 11-10-2010 | 05:55 PM
moodyj's Avatar
I am having the same error message but the code is different, it matches the hex code of my truck. I am thinking that I had some left over custom code on the truck for my "stock" tune (I bought the truck used and I wonder if although he brought the truck back to stock he left the tire size changed.) so when the Edge tried to read the stock tune it did not jive. the fine print also mentioned something about being able to download the factory tune.
So then I plugged in to the Edge Fusion software and now I think it is downloading the factory tune for my ford truck to save. Then it will update to a custom level knowing it has the factory one to fall back on.
does this make sense?
Old 11-10-2010 | 06:11 PM
What edge unit>>> CS CTS or monochrome???
When you hook it up to update it to fusion, fusion will check the programmers memory and if the current hex calibration files on the programmer are out of date it will update them to work with new or revised hex codes.
And...
If needed it will revise the firmware...
Fusion doesn't look at what trucks have been linked to the programmer.
Follow the advice that JackandJanet posted if that doesn't work edge might have to be called......
Quick Reply: Another edge question
