What's the way to go chip or tuner?
Old 12-29-2008 | 02:52 AM
Furm1350's Avatar
What's better chip or tuner for More horsepower and better Mpg ?
Old 12-29-2008 | 06:52 AM
a custom tune via xcal2, xcal3, diablo or gryphoon
don't expect a million horsepower and some supporting mods will help
suchs as e-fans, underdrive pulleys, long tube headers and a tuned exhaust
Old 12-29-2008 | 11:40 AM
JackandJanet's Avatar
x2, except the last one's spelled "Gryphon".
Look through these threads and you'll get a feel for what each offers. You're not going to find a "chip" that will do what you want.
- Jack
Old 12-29-2008 | 12:02 PM
Drkharbinger's Avatar
Well, that is like asking do I want to have a big mac or a ribeye. Get the tuner, the above mentioned are the best around, but everyone will have their praises about all of them.
Old 12-29-2008 | 03:52 PM
ASEMechanic's Avatar
The only really good reason to go with a chip is to be able to change programs on-the-fly. On a gas vehicle, there is limited need for that so a programmer is most likely the better option for you. One thing to also keep in mind is that most chips are usually a bit less expensive so if you're on a budget, that might be a consideration.
Good luck.
Old 12-29-2008 | 04:53 PM
dexx00420's Avatar
Forgive me if this is a dumb question but is it possible to have both?
Old 12-29-2008 | 04:57 PM
solomonHk's Avatar
I prefer tuner/Programmer. But what you should keep in mind, its not just about HP. Its moreso about they way your truck performs, shifting, lag, et al. While HP gains may be nominal, the change in behavior is well noticeable.
Old 12-30-2008 | 12:28 PM
Furm1350's Avatar
So I should go with a programmer can someone send me some good links to these ? Thanks
Old 12-30-2008 | 12:32 PM
Quick Reply: What's the way to go chip or tuner?
