Superchip help
Old 12-30-2008 | 03:00 PM
baseballf150man's Avatar
Superchip help
I have a Superchip Flashpaq and I waswondering if anyone knew what to do about shift points and WOT?
Old 12-30-2008 | 03:15 PM
Dankle666's Avatar
I'm not sure what the question is here? You can put them on SC VALUE and see if you like the way it is, if not then adjust accordingly. If you are a little more specific I might be able to offer better help.
Old 01-04-2009 | 08:23 PM
LegIron's Avatar
You can adjust both up or down from the default SC setting. I know it doesn't give you a specific value for that setting but you will know after driving it if it has made things better or worse for you. Try it and remember you can always go back to the SC settings.
Quick Reply: Superchip help
