Question about speed calibration accuracy
I got my Gryphon in this week and recalibrated the speedometer for my tire size. I compared it with what my Escort Passport 9550i said my speed was and they are about 4-5 miles/hour different at 70. Passport is the higher speed of the two. Which one do I trust? Gryphon should be accurate because of the number crunching but the Passport uses GPS to determine speed. I would like to know if I have been speeding this whole time going off the Passport speed.
There's been MANY posts in this forum on this subject. If you have a GPS, or a cop's radar gun, or if you do it the old-fashioned way like I did it at first with mile markers, and, if those numbers are different than what you are seeing on the Gryphon and the dash speedo, then I have to say the numbers you are putting into the Gryphon are wrong.
If you are really going faster than the speedos tell you, your tire size is too large. Reduce it. A 5 mph error at 70 mph is about 7%. reduce your tire size about 7%. (But, make sure your gear ratio is correct first).
- Jack
- Jack
I checked my Gryphon with my GPS after installing, the Grypon and GPS showed the same speed but the dash speedo showed me to be 1 or 2 mph faster. I remember reading here or on PHP forums that the ford speedo's show 1 or 2 mph faster anyway. My stock f-250 shows about 2 mph faster than a GPS also.
- Jack
In my case, the 2 mph error is only about 1 mph in the 35-40 mph range.
- Jack
Lets just say that fords estimated error for a speedometer is +/- 1mph, or even 0.5 mph. That means they need to set it so that with the error, you aren't speeding. Could you imagine the backlash of Ford not considering this and 10000 people get speeding tickets because their speedometer was reading lower than it should. Just a thought at least.
A GPS will be the most accurate. It calculates speed based on distance and time.
Except, fitz - the odometer reading seems to be right on with the speedometer reading 2mph faster than actual. I've learned to just accept it. Maybe Ford IS trying to keep you from getting a speeding ticket!
- Jack
- Jack
