Edge tuner tire size Help
I dont have that size tire, but i figure mine out by measuring 1 whole revolution of the tire on my truck. I think its more accurate than the tire calculators. For example my truck has 275/55/20 and the calculator says they have a circumferance of 2545mm, however when i measured i got 2480mm. There is some squish factor but rim size and tire brand come into play also. Hope this helps Here is a calculator: http://www.1010tires.com/TireSizeCal...?action=submit
The Edge manual listings nor their formula takes squish into account. You have to reduce their number by 3% to 5% depending on your specific tire.
Keep in mind that not all tire brands measure the same, rim width can also come into play as well. So your most accurate answer with be measuring 1 full rotation. If you dont have a metric tape measure just measure in inches and convert it either online or most cell phones have conversion calculators.
