more?
since every has the same truck as you and we have all used the same intake as you are inquiring about anyone can answer your question with a good estimate
fill in the blanks so you can get a good educated questimate answer
MAKE
ENGINE
TRANS
GEARS
OCTANE OF FUEL (you plan on having it tuned for)(91-93 octane yields greater results than 87 crap gas)
CURRENT MODS
MAKE
ENGINE
TRANS
GEARS
CURRENT MODS
Crash, the custom tune WILL improve your HP and torque. How much? It's VERY hard to tell. But, I don't think I've read of anyone experiencing LESS HP and torque after getting custom tunes from PHP, VMP or TP.
You put big tires on your truck? It'll feel like a dog. Add in higher gears? Your truck will start to feel peppy again. Can you get back everything you gave up by making these changes? Maybe not. Power and torque are a balancing act. Any change you make will improve one set of numbers, but will probably degrade another set.
A CAI CAN improve your air intake volume at high RPMs, but it can also make you run lean. The exhaust probably does little more than change the sound. The big tires cost you in torque, and probably increase rolling and wind resistance. Higher gears increase your low end torque, but limit your top speed and hurt your gas mileage.
What is it you want?
- Jack
- Jack
