No hex code
No hex code
I searched for a answer but am still confused..
Some of you may know I was having some problems a while ago with my evo. I thought I had it fixed, but today (my second day driving it) I realized it doesn't show me the hex code during startup, goes directly to the main display screen. The first time I ever plugged it in it showd the hex code but said it needed updates. After the updates no more hex code.
I've also noticed it causes some studdering in 3rd gear between 1200 and 2100 rpm between speeds of 25-35. If it drops to od then it does fine. If I excelerate right through the gears it does alright too.
Could the hex code and studdering be related and what do you suggest that I do? I am afraid it isn't working right.
And does anyone know if the studdering or missing I am experiencing is a little bit normal or a cause for concern?
Try taking the program back to stock once its complete shut the truck off and unplug it. then plug it back in and see if it works if that doesn't work you might have an issue with the unit. I know it should show cause i did it this morning in the parking garage at work so i could email it to Corey at PHP to get my custom tunes.
My truck doesn't studder or miss either ive got it on the canned 87 octane tow tune right now and it runs awesome.
I've tried it with the key on and off, no results either way. The closest thing I have seen trying that is for a split second I might see the screen that says "make sure key is on, do not start, and wait while initializing"
This is off the wall and may not work but its worth a shot. Disconnect the battery and pump the brakes 5 or 6 times that will completely drain the vehicle and reset the ECU. Hook the battery back up start the truck shut it off then go through all your procedures again. Could be enough juice hanging in the ECU to be keeping something open and not allowing the tuner to read properly.
To find the hex code:
https://www.f150online.com/forums/ch...-firmness.html
from edge manual
Version Info
This displays the current Bootloader, Firmware, and Calibration versions
installed on your Evolution. Your vehicle’s HEX code is also shown. Using
the Fusion® software, you will be able to access online updates to ensure
your Evolution is always up to date.
Version Info
I'll try disconnecting the battery tonight after work and see what happens.
I was able to find all the information and hex number and other info in the menu, I sent a pm to Bill with that info, I've read on other threads that he is the man to talk to, and hopfully I can get some insight to what might be causing the engine studdering and missing.
Thanks for all your help everyone! I appreciate it.
well i disconnected the battery to reset the keep alive memory. it seemed to help right at the start, I took it for test drive. Later that day though it got worse and eventually was having the same problem, mostly just 2nd and 3rd gear between 1200 and 2200 rpm or so it just studders and misses so bad. I just cant put up with it.
I can't figure this out and am so frustrated rightn now. Is there anyone else out there who has had this problem? Is there anything I could do to possibly fix it or am I just out the $300?
