Edge on level 0
Old 03-07-2009, 12:21 PM
greencrew's Avatar
Edge on level 0
What can I do with my Edge Evolution if I don't run the canned tunes, but just keep it on level 0.
Will I be able to change tire size, shift points, and rev limits?
Old 03-07-2009, 12:39 PM
rednoved's Avatar
I don't think you can adjust settings for Level 0. It is the stock program that comes on your truck, so I wouldn't think you can change it. I haven't tried though.
The things you want to change are settings in Level 1(Transmission Only Program).
This setting is the lowest level setting. It will provide firmer transmission
shifts which helps to increase the transmission life. It does not provide any
engine performance increases and is designed to run with regular unleaded
(85 to 87 octane) fuel.
Old 03-07-2009, 12:42 PM
Super Moderator
Level 0 is your stock tune so you can't change any setting. The only thing your Edge can do for you on your stock tune is the monitor read outs. You need to have it on at least Level 1 to change settings. Level 1 is just a shift tune.
Old 03-07-2009, 02:17 PM
greencrew's Avatar
Thanks for the quick reply. I thought that might be the case, so now I've confirmed it.
Old 03-07-2009, 09:42 PM
shorse's Avatar
go to level 2 and enjoy it... why do you have it if you arent going to use it?
Old 03-07-2009, 10:01 PM
Probably to use all of the other options it offers. Temperature read outs, economy read outs..
Old 03-07-2009, 10:43 PM
greencrew's Avatar
I have a FFV so it does not work with my truck. I need to call tech support to see what my options are.
I still like the read out options it offers, so I'll keep it either way.
Old 03-08-2009, 12:26 PM
lObOdiablO's Avatar
so what is involved in level 2?
Old 03-08-2009, 10:55 PM
greencrew's Avatar
Level 2 is enhanced performance with 87 octane gas.
Old 03-09-2009, 02:32 AM
ATOM's Avatar
what don't work?
Old 03-09-2009, 04:07 PM
greencrew's Avatar
The Edge does not recognize my truck.
Old 03-09-2009, 10:01 PM
ATOM's Avatar
the one i bought used had the same issue, mine could not be update. edge ended up sending me a new one free in return i sent mine.
Old 03-09-2009, 10:15 PM
bjp207's Avatar
call PHP and see if they can do anything for you
Old 03-09-2009, 10:25 PM
JackandJanet's Avatar
Super Moderator
I'd guess the firmware in your Edge is out of date. Edge tech support should be able to get you up to speed.
- Jack
Old 03-09-2009, 10:31 PM
ATOM's Avatar
yeah that's why he said on the phone and the model i had could not be updated online
Quick Reply: Edge on level 0
