Recommendations for a 4.6
I have the 4.6 in my truck and a superchip programmer in there now set to performance, but can't tell alot of difference other than worse gas mileage. I see people recommending the Xcal and others. I was trying to see if anyone had went with a superchip and then switched to something else and saw any big difference.
I have a superchip. 2007 4.6. On the scangauge i picked up 10-15 hp in perf. mode. The mileagexs program picked up 2-3 hp and almost 1 mpg. You might check the octane of your gas, because if it is below 91 it will not help you, you need to put it 87 perf. and use 86-88 octane, this got me 8-12 hp.
on
The only thing more it offers is a visible mounted display. I can use my X2, load PIDs into it and scroll between information if i really had too. But what is the need if my tuning is right? All fail-safe strategies are being used, so me seeing what is happening is irrelevant because the computer is taking care of it.
