what should i get first?
on
If you are going to modify the vehicle get the tuner last. Be sure to let your tuner know what mods you plan on adding so he can account for the changes in the tune. When I say last I don't mean to wait six months to get the tuner. Ideally you should get the tuner at the same time you get the mods.
Also realize that custom tuning will take about 4 - 6 weeks to be filed until you can receive the tune file and program your truck, so I wouldn't install the headers or a CAI until you have the Gryphon tuned and updated with the custom filed tne ready to install. So in general, buy your parts, then send for the gryphon, wait for the tune to be filed and transfered, then install everything with the programmer being last.
Where did you get that info? Exhaust flow changes VE, the only VE tables used for fueling are the LWFM tables. And those tables are used during tip-in/tip-out depending on what the PCM is using transients tables or LWFM tables. There wouldn't be a problem, but i still suggest a tuner first as it has a LOT more to offer.
OP, get the tuner first and get a tune for stock and a tune for the mods.
