Edge Evo + My Gas Mileage Stats
Just wanted to put this out there about an experiment I did with the Edge Evo and my gas mileage and settings. I have ran the tow tune for two weeks running low octane with an average gas mileage of 15. And I ran two weeks on the performance tune with an average gas mileage of 17. And to be fair to both settings I drove my truck in the same area/route. I was able to do this because I was in the process of breaking in my new gears. So I put the numbers down in excel and I figured it cost me an additional 0.80 cents to run the higher octane in the performance tune which I gained an additional 50 miles out of the 25 gal. tank. My numbers were $1.98 for low octance $2.28 for high octane.
I used the Edge Evo to compute my average gas mileage. I did not check it against the mileage or consumption. So the accuracy of the test may vary when actual mileage vs consumption is calculated. I plan on performing this test in the next couple of weeks.
Has anyone ran the consumption vs mileage test? What results did you get?
Way back when I first got my Edge, about 52,000 miles ago, I did the same comparison. I found that I got about 11% better mileage on level 3, driving it like a scalded ape, than I did on level 2. It paid for the difference in cost of gas and matched my driving needs much better. I used level 3 more nearly all of 31,000 miles before getting custom tunes. I now have an 87 Performance tune that performs better than level 3 and I save the difference in the price of gas.
I've noticed a 2+ mpg gain in in-town driving on the canned level 3 tune on my Edge with 93 octane and the timing advanced 1.25.
I was getting a hand calculated 11.7-11.9 (driving like a grandpa) every single tank I ever measured that was pure in-town when I was stock.
The first tank with my the Edge on level 3 got 13.8 pure in-town, and that was with me driving like a maniac!
I was skeptical, having had a 6.0L Powerstroke with SCT Custom Tunes, and while the low-end on the my Screw will never touch that, the canned level 3 tune has really impressed me with the top-end. 60-80 mph I feel like my Screw would keep up with my Stroke, if not beat it!
Now for a CAI, high-flow cats, and a custom tune...
You're not kidding. I've had it about a week, sort of an impulse buy in Panama City while I was on Spring Break...got it for $175 from some poor soul off Craigslist down there!
I just took a trip to Maryland which is about a 5 1/2 hour drive one way. I had my Evo set on level two and running 87 octane. I got about 18 mpg on the way down and about 16.25 on the way home. I noticed that the Edge readout and my Truck readout where about 1 to 1.5 MPG off from each other (Edge was lower). When I did the actual calculation my number was right in between the two.
just got an edge evo and on level 2 with 97 the edge ave mpg says 14.5- 15 mpg the actual is 13.9 could this be due to a short duration af accumulated average? or could i have it set wrong? i used the 2792mm number they give you in the manual for 35" tires. i was hoping for a spot on calc from the edge. ideas?
To verify the speedo (tire circumference), use a GPS or mile markers.
