edge problems
I'm glad I'm not the only one confused here. First, he has a fifth gear, then hes got a "locked" tranny that's "slipping". Maybe, he was trying to climb the hill in neutral (the gear position just forward of "Drive")?
And, Jdiddy, shift firmness will not cause the tranny to "lock" or "slip". It simply changes the time interval between clutch release and re-engagement during a shift.
- Jack
- Jack
when i first put the edge programmer on my truck i noticed the torque converter doesnt unlock on an incline unless i press the gas a little harder than normal. imo superchips flashpaq felt a lot better at shifting.
- Jack
the problem is that there is no throttle response when the tc is locked. with the factory settings my truck could accelerate enough to maintain speed on a small hill without unlocking. now when i gently press the gas the rpm's dont change at all, i have to press it hard enough to make it unlock to get any response from the engine.
sorry overdrive, you know 4 speed with overdrive. and yeah itdid lock up, put it in reverse and didnt go anywhere. just rolled back two feet then LOCKED up. then i brought the rpms up to about 2500 and then it slammed into gear.
and thanks for just saying **** instead of helping me
well appriciated
well appriciated
