yalls tune on the edge
i installed my egde on the other day and started messing with the custom tuned part right now its set with> 1-2 5500 with 18 shift firmness 2-3 5600 15 shift firmness. rev limiter at 6000. WOT fuel 1.71 and 1.25 timing advance so far its been pretty good best 0-60 is a 8.18 with 4.10 gear and 305/55/20
mods: banks exhaust and the tuner.
I really wouldn't bump the shift firmness much above +12, +12 and +9 for the three shift points either. The "firmness" settings reduce the time between clutch release and clutch engagement. If you make it too quick, you put pretty severe strain on the drivetrain.
Unless you are burning higher octane gas than the tune is set up for, I'd leave the timing at 0. You may be getting detonation, even if you don't hear it.
And, I doubt you need 1.71 WOT fuel. You'd probably do just as well or better with 1.3 or 1.4.
- Jack
The +1.25 on timing is probably safe. That is what I ran on mine before I got custom tunes. Edge was pretty conservative, so I think it is safe. I ran the WOT Fuel at 1.5, this was per Edge's recommendation.
One thing to keep in mind, the 3-4 shift is the weakest point in these trannys, I would not go over 4800 rpms with that shift and I would keep the shift pressure on that one at about +9.
Plus, I agree with Jack in that you are pushing all of it a little too much for my comfort, and you get diminishing returns. I would try 5200 rpms shift points for 1-2 and 2-3, plus I would try a shift pressure of about +12.
You are correct in keeping the Max rpms at least 400 above your highest shift point. That is important.
So, WOT fuel is just an upper limit on fuel input in open loop - and you get peak torque at a lower A/F ratio than stoich.
The 1.5 advance in timing in the Edge manual is probably a typo. In another place they say to advance 0.5 degrees for each octane number. Since 93 -91 is 2, I'd think they meant to say advance by 1.0. I was worried you were burning 87 octane gas in an 87 octane tune and advancing the timing on that.
- Jack
im a little confused and have a question as well. i have a 2004 (lean running) f150 with a cold air intake. people have told me i need a custom tune to fix the issue. but is it the WOT fuel adjustments that needs to be tuned? if it is, then cant i just customize the edge to fix my problem?
If you have filled with 96 octane gas, you should be able to advance the spark 0.5 degrees for every octane number that gas is above your current tune. So, if you are running Level 3 (91 octane), you should be able to add 2.5 degrees to the timing.
- Jack
