dumb edge question!
dumb edge question!
When I installed and setup my evo the other day, I only change the tire setting and the rear end setting and set it on the #2 towing setting! when i start my truck it has the 2 in the right hand corner, but if i go into my settings for the #2 towing is shows all the default settings....is this right? I figured that it would show the tire/rearend changes that I made....
Here's a Q & A I wrote on the Custom Options menu for the Gryphon. http://dygytalworld.ehost-services13...ead.php?t=1101 The Edge is much the same.
- Jack
