Sluggish throttle
Sluggish throttle
I've got a problem that I can't figure out what is going on. I have Troyer custom tunes with 3.5" AF1 tube. Had this setup for about a year now, I have noticed lately that when I come to a stop and I start again (ie. red-light or turning) the engine is sluggish when I press on the gas a bit it almost seems to miss and run bad, when I give it more gas and the trans shifts it runs fine. It mostly happens when I am very light on the throttle.
I cleaned my MAF sensor wire with electrial cleaner and that didn't work. Is there a potential problem with the tunes? Does anyone with Troyer tunes and the AF1 3.5" had this problem?
Any help is appreciated,
Thanks - Andy
Thanks - Andy
No. All it will do is clear the Adaptive Memory or whatever it's called. It has adapted to your driving style and if you have done a lot of city driving, slow starts, etc, that is what it has adapted to. Clear it and start over. If that does not do it, then it might be something mechanical. Your tunes are stored in the computer and will stay stored until erased.
