edge cable
edge cable
I have an edge programmer, and I somehow lost the little cord to plug into my pc to update it a while back. Where can I find a replacement? It looks like toward the OBD plug it splits off and there is a 4 pin plug of some kind, into which you plug the USB cord. I emailed edge a while back and they were no help. Any suggestions?
Where does the mini b plug in on the programmer? The only plugs I can see on mine is the OBD plug and another one that looks similar to the one that plugs in the back of the module, but instead of six pins, it has four. Im sorry if I sound like a moron, im just trying to figure this out.
![](http://www.usdieselparts.com/imagesWeb/EEF2400.jpg)
The programmer is constantly plugged into the OBDII port in order to program your computer and to run diagnostics and gather DTC's.
I believe that is the "4 Pin Plug" you are speaking of.
I suggest going to www.edgeproducts.com and downloading a copy of the users manual for your evolution.
It isn't very long, and will probably answer all of your questions.
Take a good look at your plugs and your evolution when you get it back I'm sure it will be all pretty obvious to you when you actually see it.
![Llama](https://www.f150online.com/forums/images/smilies/llama.gif)
![lol](https://www.f150online.com/forums/images/smilies/lol.gif)
Rednoved posted a picture of the kind of cable you need to connect the Edge to a PC. It's a standard USB cable. The OBDII cable is not used with the PC at all.
- Jack
Last edited by JackandJanet; 08-16-2009 at 04:48 PM. Reason: Finally figured out the question.
