Edge
Edge
I ordered a new Edge for my 07 4.6L to-day. I understand that there are three canned tunes Performance, Tow and Stock. I do not tow anything. I am looking for a little better performance and hopefully a slight increase in milage, which canned tune would be best. There was mention of a tune on this forum for fuel econamy, did I miss this or is it a tune to be added? I have stock 20 inch rims on this FX 2 with 3.73 gears, I have increased the tire size slightly should I change this in the Edge before or after I program??
Ok, here we go. Level 1 is just a shifting tune. Level 2 is a towing tune, gives great low end improvement but runs out of steam on the highway, in the upper rpms. Level 3 is a performance tune that pulls till you let off. Levels 1 and 2 are for 87 octane. Level 3 is for 91 or 93 octane. Normally, level 3 gives enough mpg improvement to pay for the price difference.
On any of the 3 tunes, you can adjust your tire size with the Edge. To get more economy, you will need custom tunes, you get those from PHP. You will need to convert your Edge to the Gryphon to get custom tunes.
Hope this helps some. The Edge is good, the custom tunes will be betetr if you ever decide to upgrade.
With the firmware update, the Gryphon will accept custom tuning. To be CARB certified, Edge cannot allow their units to be custom tuned.
I understand your hesitation in changing the program in the PCM. I was a bit nervous the first time too. Just read the manual you get with the unit and follow the directions - they're actually quite easy. Your battery needs to be at a good charge level and you simply let it do its thing without much intervention the first time through.
If you run into problems (rare), Bill Cohron can get you going again and will do so free of charge. Still, do the first program during the week, probably at home so it's easy to call for help if you need it and you're not stranded.
- Jack
Bill is a consultant and programmer for Edge as well as owns his own company, PHP.
Edge and Trans
I was reading on another forum were a fellow had indictaed that he had experianced some problem with his trany using the Edge on level 3. What is level 3? I understand the terms Performance, Tow and stock is one of these level 3?
Please read my post #2. I explained the tunes. The stock tune is what your truck came with. Level 1 is a Shift Tune, Level 2 a Towing Tune, and Level 3 is a Performance Tune. Level 3 should not cause a problem with the transmission unless it is weak to start with. I put 31,000 miles on my truck with Level 3 before I went to custom tunes. I now have 91,000 on it and never a problem.
