Programmer, needed first before everything else?
So I've been on the forum for a month now and as I've been reading about tuners (finally figured out who Bill/PHP was, dont laugh) and seen different post about what is best to added and what is just for show. I am wondering is it better to get a programmer first, then add intake and exhaust or would it be fine to do it the other way around first?
I'm just looking to get the best for my truck, I love the thing how it is, but the better fuel economy and shifting, etc. sounds amazing though.
So just need opinions!!!
First, welcome to the site. I hope you have deep pockets, because if you spend any time here at all, you'll be tempted to spend too much. Next, to get the most out of many modifications, you'll need to get a custom tune to account for that modification. Exhaust modifications behind the cats don't require a custom tune, but any intake modifications or headers and new cats/deleted cats require a custom tune. So in my opinion, the answer to your question depends on what mods you have planned for the future. You could always start by purchasing a tuner and using the canned tunes that come with it, then add custom tunes once you've completed all the mods you want. If you're planning to have custom tunes in the future, you'll need to make sure you get a tuner that can be custom tuned. Last, if you haven't already, see the sticky at the top of this forum for a ton more information about tuners.
Intake/Exhaust before the tunes, that way Bill can compensate in the case your A/F ratios are off.
Save up and spend the little bit extra for the Gryphon, that way you have peace of mind that your tuner is custom to your specific truck and mods. I just paid to upgrade my Edge to a Gryphon.
Okay. I'll definetly get that before I think about custom tunes. Honestly thats way down the road, so I'm just looking for something a little extra for the time being. Thanks.
So you cant do custom tunes with the edge?
And another thing how can you tell what gear ratio you have going?
One little edit, where can I get a Gryphon?
Nope no custom tunes with the edge. You can make "custom modifications" by going in and changing your gear ratio, tire size, etc, but it's not truly custom. Bill makes each tune custom to your truck. If you've got a CAI, dual exhaust, high-flow cats, etc, he will tune it to match your specific mods.
When I did the upgrade I paid for two custom tunes: 87 performance and 93 performance, with the number referring to what octane you run the truck with.
The Edge programmer is anywhere between $350 and $400 new. The Gryphon is $400 new and it's $30 per custom tune. So you're essentially paying only $30 extra per tune specifically for your truck and mods. Definitely worth it, IMO.
Gryphon for 1997-2003 F150. Click on the left to navigate the site.
http://dygytalworld.ehost-services13...e_Vehicle.html
edit-Check your gear ratio by opening your driver's side door and looking at the sticker on the side of it.
I just got an SCT X3 from VMP!!!
I have stock 07 5.4 xl, and I'm running a custom tune (91 performances) with no problems (well at least for the last 2 hours ) , also am planning to get Intake/Headers & Exhaust next, so as soon as I install them, I think I should request for another tune from Justin VMP...
am happy with the power difference!
If you're running stock gears it won't matter. Just make sure and see if you have 3.55 or 3.73 and you can change that yourself anytime. You'd only have to worry about it being part of the custom tunes if you re-geared to run larger tires and a lift.
Dash-mounted pod with Edge on left. My pod is currently empty while Bill upgrades the Edge to a Gryphon and writes the custom tunes. Looking back I wish I'd have just ordered the Gryphon first....
edit-forgot to mention, the Gryphon is black, so when I get my Edge-->Gryphon upgrade back it will be black inside the pod.
