edge programmer performace level question
i was reading the manual to the 97-03 edge programmer and it said you HAVE to use the 91 octane gas for the performance level tune. is this true???
will the little difference in gas really make a difference or will i hurt my ingine by using unleaded gas?
thanks
justin
thanks
justin
thanks
justin
thanks
justin
The 91+ Level 3 tune has timing advanced and fueling that is set up for the burn characteristics of the high octane fuels. It is NOT a good idea to run a lower octane fuel in this tune, even if you retard the spark. There are other things you cannot change that are not good for the engine. If you are using a 91+ octane tune, DO NOT use 89 or 87 octane gas.
ALL gas is unleaded now in the States. Even 91 or 93 octane gas.
- Jack
