Edge questions!!!
Edge questions!!!
Ok, i understand how the tuner works when the truck is in stock form and ive also read through other posts on here to try and find my answer but im not sure if i have...im lookin to get an edge for my 2006 lariat which has a CAI, MAGNAFLOW exhaust, 8in lift, 37in tires, and stock gears. if i were to get the edge can i custom tune it myself or do i have to send it off too PHP or Troyer to get it tuned for my setup? Basically can i set up mine with the custom tunes like you would get with the gryphon? and if not whats the difference and why cant i? Thanks!
Not to mention, I dont think you will be able to correct for the lean condition you will have running an Edge with your CAI, you will need custom tunes for that.
