my new x3 is causing p1000 code
It just means that the PCM was recently reflashed.
P1000 = Check of all OBDII Systems Not Complete
http://www.obdii.com/drivecycleford.html
It should go away though, the problem with it being there is if you are required to have your vehicle inspected, they will not pass you because of that code.
And, I'm puzzled that the P1000 code is being set with a custom tune? He really does NOT want the PCM to relearn the stock fueling strategies, so normally, I think, the tune should prevent the code from being set. Did you by chance disconnect your battery at any point in all of this? If so, that is what set the code.
If this is the case, my advice would be to return the truck to stock, drive it around for 50-75 miles to clear the code, then try reprogramming it.
- Jack
- Jack
