Edge Evo, level 2 and trailer weight
Old 03-19-2010 | 08:18 PM
mugsaway's Avatar
To the OP:
You need to figure out your total combined weight of the trailer and payload.
Edge/Gryphon performance tunes are only rated up to 2500 lbs for towing.
The edge towing tune would be better.
Just read this from another post. Could be a really dumb question, but what if I am using the Edge on the tow package, pulling a trailer weighing 3000 - 3500 pounds?
Old 03-19-2010 | 08:20 PM
shotgunz's Avatar
Level 2 (tow) is the correct tune for anything over 2500 lbs. Levels 1 and 3 should not be used to tow anything over 2500 lbs.
Old 03-19-2010 | 08:40 PM
mxzeatr's Avatar
Is it fine to run the 'Tow Tune' while empty too? Or should you go back down to level 1?
Old 03-19-2010 | 08:51 PM
shotgunz's Avatar
You can run level 2 without a load, but your MPG may suffer.
Old 03-20-2010 | 06:41 PM
JackandJanet's Avatar
In my experience, economy did not suffer when using the Level 2 tow tune and not towing. It actually improved over stock. Possibly, the Level 1 tune COULD be more economical, but since it is a transmission only tune, I doubt there would be a significant change. I thought the Level 2 tune was a good daily driver tune.
Bluejay, felt that it lost power in the higher RPM ranges. I didn't notice that myself and really liked the way it performed while passing someone on the highway. I suspect some of this is subjective.
- Jack
Old 03-20-2010 | 08:11 PM
- Jack
If subjective means you are an old fart and can't tell that you are losing torque at higher rpms, I think you are correct.
Old 03-20-2010 | 08:12 PM
mxzeatr's Avatar
- Jack
Thank you for your input!
I just purchased a used Edge today. Don't have the coin to go Gryphon just yet, so want to get used to the unit and see if I like whats going on. Then I might just get it upgraded. I love how the truck performs now (much better then my old cheby) so any gain is going to be better. I do pull quite a bit, so the changes to the tranny in level 2 should be very fitting to my needs.
Can't wait to get it hooked up and start learning what its all about!
Old 03-20-2010 | 08:29 PM
shotgunz's Avatar
Ouch!
Old 03-21-2010 | 05:03 AM
pdxsenior's Avatar
please define "old fart" so I'll know whether or not to put myself in that catagory and know if I should look for threads dealing with "old" and "fart" only or just not-the-sharpest-pencil-in-the-box info.
Old 03-21-2010 | 10:15 AM
"Old fart" is more a state of mind than age. Jack is just 3 or so years older than me, but I'm not an "old fart". You need to study his posts and you will see what I mean. I'm still a kid.
Old 03-21-2010 | 04:58 PM
mugsaway's Avatar
Yes, I am a noob. But, that is why I continue to ask questions - pointed at those who know. In the tow tune, if I am towing a trailer, wouldn't I want torque in the higher RPM range as well as the lower?
Old 03-21-2010 | 05:01 PM
Jim and I noticed the same thing. An 87 performance solved that... MPg's are at last summers level too on the current winterblend.
Old 03-21-2010 | 05:06 PM
What I experienced with my truck was running on a two lane road and needing to pass at 60 mph, hitting it, level 2 just did not pull that hard. Same on the freeways around DFW. With the level 3, it pulled hard till I let off. So, When I got the custom tune, I told Bill that I wanted it to pull hard all the way and I wanted it to kick down to a lower gear at almost any point. He nailed it for me.
Old 03-21-2010 | 05:15 PM
Jim is spot on... the custom tuning fixed it. Pulls all you need. 2 would crap out when merging. I have punched it a few times and I am up to speed very quickly
Quick Reply: Edge Evo, level 2 and trailer weight
