Wont take my truck
well, for starters how about some basic information since we can't see thru the internet
the device might not be unlocked, it might not be compatable with your truck, the list could go on and on but no one wants to sit and here play guessing games when a lil' info could help narrow down the issue
Sorry wasnt sure what info would be needed. It came from an 06 and mine is also an 06,both have the 5.4. I was able to run through all the choices and look up options and what not but when I gave the ok to run a choice it said truck not registered and went back to the beginning. What other info is needed.
Ok, I believe the programmer is VIN locked. When a programmer is used on a vehicle, it will only work on that vehicle. With the info you just gave, it should be compatible. However, the programmer probably needs to be sent to Predator so it can be unlocked. I'm not familiar with predator, but SCTs work this way. Unlocking on an SCT costs $150, it ain't cheap. If you know the guy you got the tuner from, having him put his truck's tune back to stock may be a way to get around this. The companies do this so that you can't get one tuner and run around tuning everybody's trucks with it.
