No Warranty Footprint?
Just an fyi-
Custom Tuners- Reprogramming Detection
http://www.flatratetech.com/communit...ne#entry220469
Posted 07 June 2012 - 12:30 AM
Fullsizeblazin “They most definitely can! Once they pull the Mode 9 file on the IDS all your dirty little secrets will be revealed and your warranty will be promptly voided.”
Diablo
What kind of number are you getting with the Diablo tuner?? Will you give me the "No trace left behind" or you'll pay for my repairs guarantee? I just find it hard to believe that it doesn't have a data log when the system is accessed. Even an old Windows 95 desktop logged usage. The average "tech" doesn't have the ability to read it in print as I'm sure it's all binary, but if it came down to a catastrophic failure, I would think that they would have the means to find out. Just like the "event recording" features the OBDII systems have. Anytime a DTC is triggered, they know all of the parameters before and after the light comes on. TPS position, fuel mixture, boost, gear selection, RPM and more. Sure you can clear the code, but how can you be certain there's no timestamp of access?
As far as the link to the "Powerstroke Tech's" story, It would have been far more believable if he was more professional in his delivery and didn't refer to the owner as a douche bag every other sentence.
I'm just looking for a little more mileage, a little more get up and go.
I want to make everyone aware, it is perfectly legal to own an IDS, and to have a subscription to IDS, thus allowing you to flash/update vehicles anytime you wish. Your local mechanic may well have one. Do you think that if your local mechanic, or neighbor, flashes your PCM, then you wind up at the dealer the next day, they are going to void your warranty, based soley on the number of key cycles?
Let me ask this, what if your car was just parked for winter storage, and you connect the battery and find an issue, and have it towed to the dealer, are they going to void your warranty for no key cycles?
I'm just taking the long road to say that key counts are NOT grounds for a warranty issue by any means.
Our tuners offer solid gains, about 20 rwhp on premium fuel, along with better throttle response, and improved shifting, and a bump in mileage on the highway
![Smilie](https://www.f150online.com/forums/images/smilies/smile.gif)
Just an fyi-
What exactly do you think they can see in a Mode9 read that will say you have used one of OUR products??
Average gains are 20 rwhp/20-25 ft/lbs on premium fuel.
I cant put anything in writing, as it is sure to be abused. You must tune at your own risk, in the end, its all that matters.
I think that dealer relationships are going to be key in these situations... I Like that Mike has a presence on this forum there for I am likely to go with his tuner, My only concern was if I am away from home and have a failure can I pull the tune out and still be covered, My dealership said they have no problem with programmers as I am a loyal customer just not to abuse it... I just want my top speed raised, and tire size re calculated...
