Help with Edge Tuner
on
if its the monochrome edge evolution....
hopefully yer buddy's was from an 04-08 f150....97-03+04h model won't work...
if its the cs/cts"c=colored screen"...one model will work on all years
read this sticky>>>link>>> https://www.f150online.com/forums/ch...ions-menu.html
Edge's website>>>link>>> http://www.edgeproducts.com/products...tegory_key=all
i have an EVO i have upgraded my tires a little bit larger and found that when i put in the stated tire size of 2600mm my speedo was off around 4-5 mph reading slower then gps. so some fin tuning may be in order if you end up having a problem. to get mine almost dead on i actually had to adjust it to 2503mm. Good luck anything else its a great product second one i have owned and installed in ym trucks.
