Tire Size Not Updating
I plugged in the Edge and did Level 1 and tires were 7% off, changed the value to 2600 (285/71R17) and tires are sill 7% off. Changed it to 3000 and no difference.
I'm going Lvl 2-> Custom -> Tire Size (2600mm) -> Done.
I can't remember if I loaded a stock tune first, or went straight into custom tunes (mistake, I know). Any way to clear everything out so it can "relearn" it the proper way?
First - load the stock calibration. Then Restore to Factory Defaults as described on Page 38 of the Evo manual.
http://www.edgeproducts.com/product_...manual-277.pdf
As fer TS not 'sticking', there is indeed a specific sequence to follow - as explained (many times already) by Sir Jack: https://www.f150online.com/forums/5027834-post12.html
MGD
Has it EVER worked ?
You'll need to consult Sir Jack, or Sir Bill.
I only use my 15051 for more gauges (daisy-chained with a Scangauge II via a custom homemade cable). I be an SCT feller fer tunin'.
I'd keep the Gryphon at least - and see if you can get this issue resolved by PHP.
Good luck.
I talked to bill about it when I had my gryphon tuned and he said there wasn't anything he could do about it, he even tried fixing things through the remote desktop after I got the custom tunes.
Since I know that the Edge worked on my dad's truck, I was hoping it would work on my truck as well. I reset everything last night and drove the 25mi to work. I'm going to load the custom tire size tonight for the drive home and see if that works
glc, Since he has the older (monochrome) Gryphon, he can update the firmware using Pegasus (from PHP), using [Updates]->[Gryphon Update Manager]. That WILL put him back to canned tunes, but then he should be able to restore the custom tunes by clicking on [Updates]->[Custom File Download (Internet)].
You don't use Fusion with his model programmer.
It's worth a try, but I'm somewhat doubtful of the outcome being any different.
- Jack
- Jack
