superchip 1715 for 97 f150 questions
I have a chance to buy a superchip 1715 tuner for my 97 f150 for cheap and wss wondering if it woukd be worth it? But ive heard these tuners are supposidly limited on the older f150's, ive heard complaints of people not being able to run an 87 octane tune and only being able to get a single superchip tune, was wondering if this is true or not? And if this would be a good tuner?
I dunno - that's the last thing you want to do to an engine that you can't get to stop pinging. Take the money you would pay for it and get someone who knows what they are doing to look at it.
https://www.f150online.com/forums/v8...lp-please.html
Wellsir - if yer truck maintenance be up to snuff, yall got fresh plugs, front O2's, fresh fuel filter, yer chambers ain't carboned up, yer cats ain't clogged AND you ain't pingin' NOW, you can give it a shot.
*** And now, the BIG Ol' CAVEAT: NO programmer will FIX a pre-existing mechanical, electrical, or drivability-related issue with the truck!!! **** don't even go there. Bad, bad, Juju. Very bad.
HOWEVER - DO NOT pay a lot for this ancient device! No more'n $72.96 - $97.60 tops, as it is obsolete and wont work on newer tucks. Free wuud be good , too. Be advised - these here thangs NOT be customizable, updateable, or anytang like thet!
There be two versions -
- original version = had only one 91 octane, tow-safe tune, so yepper... yall needs to ran the expen$ive hooch
- newer' version = had 3 tunes - including an 87 octane one and a couple 91 octane files, so that would be the one to get.
I wunt pay fer the original 1-tune unit. Nosiree...
Thing is, they look identical - you'd need to plug 'er in to see what version it is, or get a screenshot, OR git the serial number and build date - and email / call that in to Superchips to ver-e-fy exact model in play.
Here be the installation manwell fer the 3-tune booger ( sorry, don't gots one fer the 1-trick pony ):
http://static.summitracing.com/globa...s/src-1715.pdf
Summ'ry: if'n ye gots the scratch, save up fer a custom tuned SCT X3 - aboot $4 hundy, BUT it be future-proof, flexible, adjustable and a lot more effective tunin' wise
www.vmptuning.com
www.morepowertuning.com
www.5startuning.com
BTW - NO tuner cain adjust yer speedo on yer truck - the PCM dint have this'n in 'em in 1997. Need a gear fer that.
Good luck, pardner! keep them tahrs dirtside down
![wave](https://www.f150online.com/forums/images/smilies/wavey.gif)
![beers](https://www.f150online.com/forums/images/smilies/beers.gif)
Last edited by MGDfan; 11-18-2013 at 08:08 AM. Reason: Spellin'. Yeah that's right - whatchayall laffin' at ?
My 02 truck seemed slower than the 00 I had before with both equipped the same. I bought a 1715 superchips programmer from a site member and loaded it. I love it! It really perked up my 02, added an estimated 20 hp, very noticeably improved the throttle response and improved my gas mileage a little. I'm very happy with it! I tried dorking around with the transmission settings and set it back to stock. I'm using the 87 octane tune. It does have a 91 octane tune and a towing tune that also uses 91 octane. So buy it and you will be pleased I think.
Here's one tip that DOES work for a tranny setting tweak - 4th paragraph in this post:
https://www.f150online.com/forums/1950574-post2.html
Give it a try.
I tried making the shifts harder and also raising the shift points. It doesn't shift any faster just harsher and raising the shift points on a low rpm 5.4 is a waste and actually slows the acceleration. I much prefer the stock settings. Maybe I'll try the recommendation on the one shift to check again.
When I had a 1715 this worked fine for me.
MGD
