Diablo sport predator
Couple questions.
Just picked up a Diablo sport predator, used. (99F150 5.4L) MOdel U7153
I have read through the manual on how to "install a performance tune" and had no problems doing that.
First question, is there only 1 canned tune? Never saw an option for different octanes but was under the assumption there would be 3 tunes like most tuners. Went through the upload 2 times to make sure I didnt miss anything and again, never saw an option for anything other than "upload performance tune"
If that is the case though, what octane is the 1 canned tune?
I was told run 89 or retard the global spark 3-4 degrees. Just want to make sure that is the case before I go messing with it.
In the mean time I'll have to wait until Monday to get some cables and upload any updates to it.
Right now it is back to stock until I can clarify those things
Hi.
You sure it's a U7135 and not a U7153 ? Here's an application list (aboot halfway down the page):
http://www.pfyc.com/pc/GN3012//Diabl....html#moreinfo
U7153 supports yer truck, not U7135 according to that list.
Update revision pages here:
U7135: https://www.diablosport.com/support-...ult/?pid=U7135
U7153: http://diablosport.com/support-search-result/?pid=U7153
Not sure if that helps any though - kinda cryptic to me![lol](https://www.f150online.com/forums/images/smilies/lol.gif)
Predator Ford Gas forum here: https://www.diablosport.com/forum/vi...8de4c93a9305cf
A relevant post: https://www.diablosport.com/forum/vi...hp?f=9&t=47273
Everything I've seen thus far via searching suggests multiple tunes should be present.
I would not run that tune until you've: A) confirmed the model # / vehicle support, B) updated the unit, and C) gotten in touch with Diablo Mike - our rep - for his expert assessment.
Good luck
![beers](https://www.f150online.com/forums/images/smilies/beers.gif)
MGD
Good luck
MGD
My bad. It is a U7153.
I found that update page but got a little scared away when I read
"NOTE: Loading older croms to a Predator can cause the unit to become inoperable."
So I need to figure out which updates to use.
I have read from a few people there is only one "performance tune" With that model
But have also read from other people like what you have posted with that model that there are 3 so.. eh
I'll send an email out to Mike or get on his forums and see what him says
Thanks for the info.
Just found some of Mikes posts that confirm there is only one tune, at least back then
That was back in 2010 though. Maybe there have been updates since then. Not sure yet. Still hunting.
Just found this as well
U7153 Stock Vehicle Tunes
Performance Tune for 91 octane
U7153 Specific Features
Global Spark Adder -6 to 4degrees add or subtract
3000-6000rpm Timing Table (+10/- 40%)
1000-2500rpm Timing Table (+10/- 40%)
Injector size adjustment
1000-3000rpm Fuel Table (+40(rich)/-10(lean)%)
3000-6000rpm Fuel Table (+40(rich)/-10(lean)%)
Idle (+/- 20%) (400-1200rpm)
Rev Limiter , drive and neutral 6400rpm, max
Full Throttle Shift Points RPM
Part throttle Shift Pressure per gear
WOT Shift Pressure per gear
Global Line Pressure adder 0-50psi
Torque Modulation ON/OFF per gear
Increase Fuel Milage 1-3MPG
Re-Calibrate Speedometer for Gear and Tire Size Changes
Internet Updateable
And All Other Predator Features
Internet Updateable
