Speedo error with SCT X4
So my stock tire size is 265/70r17 but I've had 275/55r20's for almost 2 years and my speedo has read 4 under since and no big deal..
This is before plugging in the tuner.
When using the tuner I left the axle ratio and tire size stock and my speedo still read 4 under according to gps and roadside radars.
But when I changed my revs per mile to 630 on the tuner, my speedo now reads 10 over.
According to tire calculators, my stock tire revs per mile are 638.4 and my 20's are 632.4...
Has anyone else had this issue?
BTW, I have a 4r70w and I swapped from high stall to low stall. I'm wondering if this had an effect???
I have the x4 as well and have noted similar issues. my tires should be doing 608 revs per mile. The x4 gives the option of 610 or 605. I selected the 610, and my speedo from what i can tell is reading about 10mph fast. 70mph zones in GA where everybody normally runs 70 or less I am getting passed with my speedo reading 80 right now. I guess I'm going to adjust it to 615 revs and see if that slows the speedo down to normal.
