Question Re: Engine Codes
Hi Cougar Guy,
There are numerous reasons for different codes. Codes will vary based on which engine, which transmission, which gear ratio, which tire size, and so on, and these F-150's have numerous configuration choices mechanically, 3 engines, 3 transmiussions, 3 gear ratios & 3-4 tire sizes alone.
Now you will also see different codes for the exact same identical vehicle of the same model year, and in *those* cases, there generally isn't any difference in performance or power output, that isn't what that is about. It's generally just a very minor running update, usually some driveability or emissions issue that the driver will never be able to feel or notice. It doesn't make any difference in how the vehicle accelerates, but a different code places functions in different places, thus requiring us to do a matching code. Plus, we want to anyway, to take advantage of any aspect of any code that may ever come along. It's rare, but once in a blue moon happens.
Generally, there aren't "good" or "bad" codes for the F-150, which has 150-200+ different codes each model year alone.
